ESA 2013 - Call for papers
The symposium seeks original algorithmic contributions for problems with relevant theoretical and/or practical applications: papers with a strong emphasis on the theoretical analysis of algorithms should be submitted to Track A, while papers reporting on the results of extensive experimental evaluations and/or providing original contributions to the engineering of algorithms for practical applications should be submitted to Track B.
Deadline is April 22, 2013. 20:00 GMT (22:00 CEST, 23:00 IDT)
Topics
Papers presenting original research in all areas of algorithmic
research are sought, including but not limited to:
- Algorithm engineering
- Algorithmic aspects of networks
- Algorithmic game theory
- Approximation algorithms
- Computational biology
- Computational finance
- Computational geometry
- Combinatorial optimization
- Data compression
- Data structures
- Databases and information retrieval
- Distributed and parallel computing
- Graph algorithms
- Hierarchical memories
- Heuristics and meta-heuristics
- Mathematical programming
- Mobile computing
- On-line algorithms
- Parameterized complexity
- Pattern matching
- Quantum computing
- Randomized algorithms
- Scheduling and resource allocation problems
- Streaming algorithms.
Submission guidelines
Authors are invited to submit an extended abstract or full paper of
at most 12 pages and an optional appendix.
Papers must be formatted in LaTeX, using the LNCS style file
(available here). The
maximum length of the paper (including references, but excluding the
optional appendix) is 12 pages. Do not change the margin size or the
font, do not make a separate title page, etc.: use the LNCS style
file as given, but please do add page numbers, which can be done, for
example, by adding
\pagestyle{plain}
just before
\begin{document}
Proofs omitted due to space constraints must be placed in an appendix
to be read by the program committee members at their discretion.
These guidelines are strict: papers failing to adhere to the
guidelines (by not providing the omitted proofs in an appendix, being
more than 12 pages, or not being in LNCS format) will be rejected
without consideration of their merits.
Papers should be submitted electronically via the
EasyChair submission system.
Simultaneous submission to other conferences with published proceedings, or to both tracks of ESA 2013, is not permitted. There will be a Best Student Paper Award, as well as a Best Paper Award.
The ESA proceedings will be published in the Lecture Notes in Computer
Science
ARCoSS series by Springer-Verlag.
Each accepted paper will be allotted 12 pages in the proceedings.
