EUROPEAN SYMPOSIUM ON ALGORITHMS 2013 - Accepted papers
Design and Analysis track
Paolo Ferragina and Rossano Venturini. Compressed Cache-Oblivious String B-tree Marek Cygan, Fabrizio Grandoni and Danny Hermelin. Tight Kernel Bounds for Problems on Graphs with Small Degeneracy Stefan Kratsch. On Polynomial Kernels for Integer Linear Programs: Covering, Packing and Feasibility
Thomas Kesselheim, Klaus Radke, Andreas Tönnis and Berthold
Vöcking
An optimal online algorithm for weighted bipartite matching
and extensions to combinatorial auctions
Travis Gagie, Danny Hermelin, Gad M. Landau and Oren Weimann. Binary Jumbled Pattern Matching on Trees and Tree-Like Structures Michael Crouch, Andrew McGregor and Daniel Stubbs. Dynamic Graphs in the Sliding-Window Model Subhash Suri, Kevin Verbeek and Hakan Yıldız. On the Most Likely Convex Hull of Uncertain Points Shiri Chechik, Matthew Johnson, Merav Parter and David Peleg. Secluded Connectivity Problems Michael Fellows, Danny Hermelin, Frances A. Rosamond and Hadas Shachnai. Tractable Parameterizations for the Minimum Linear Arrangement Problem Rajesh Chitnis, Laszlo Egri and Daniel Marx. List H-Coloring a Graph by Removing Few Vertices Fedor Fomin and Petr Golovach. Long Circuits and Large Euler Subgraphs Djamal Belazzougui, Fabio Cunial, Juha Kärkkäinen and Veli Mäkinen. Versatile succinct representations of the bidirectional Burrows-Wheeler transform Lucas Bueno and Jorge Stolfi. Economic 3-Colored Subdivision of Triangulations Hu Ding and Jinhui Xu. PTAS for Minimizing Earth Mover's Distance under Rigid Transformations Ramanujan M. S., Saket Saurabh, Daniel Lokshtanov, Ondrej Suchy and Mark Jones. Parameterized Complexity of Directed Steiner Tree on Sparse Graphs Andrea Clementi, Pierluigi Crescenzi, Carola Doerr, Pierre Fraigniaud, Marco Isopi, Alessandro Panconesi, Francesco Pasquale and Riccardo Silvestri. Rumor Spreading in Random Evolving Graphs Giorgio Ausiello, Paolo Giulio Franciosa, Giuseppe Francesco Italiano and Andrea Ribichini. On Resilient Graph Spanners Megha Khosla. Balls into Bins made Faster Kim Thang Nguyen. Lagrangian Duality in Online Scheduling with Resource Augmentation and Speed Scaling Kevin Buchin, Maike Buchin, Rolf van Leusden, Wouter Meulemans and Wolfgang Mulzer. Computing the Fréchet Distance with a Retractable Leash David Adjiashvili, Gianpaolo Oriolo and Marco Senatore. The Online Replacement Path Problem Merav Parter and David Peleg. Sparse Fault-Tolerant BFS Trees Davide Bilò, Luciano Gualà and Guido Proietti. A Faster Computation of All the Best Swap Edges of a Shortest Paths Tree George Mertzios. The Recognition of Simple-Triangle Graphs and of Linear-Interval Orders is Polynomial Nadia Fawaz, S Muthukrishnan and Aleksandar Nikolov. Nearly Optimal Private Convolution Christoph Berkholz, Paul Bonsma and Martin Grohe. Tight Lower and Upper Bounds for the Complexity of Canonical Colour Refinement Radu Curticapean and Marvin Künnemann. A Quantization Framework for Smoothed Analysis on Euclidean Optimization Problems Amotz Bar-Noy, Dror Rawitz and Peter Terlecky. Maximizing Barrier Coverage Lifetime with Mobile Sensors Yakov Nekrich and Jeffrey Scott Vitter. Optimal Color Range Reporting in One Dimension Jannik Matuschke, Andreas Bley and Benjamin Müller. Approximation Algorithms for Facility Location with Capacitated and Length-Bounded Tree Connections Jakub Gajarský, Petr Hliněný, Jan Obdržálek, Sebastian Ordyniak, Felix Reidl, Peter Rossmanith, Fernando Sánchez and Somnath Sikdar. Kernelization Using Structural Parameters on Sparse Graph Classes Pasin Manurangsi and Dana Moshkovitz. Improved Approximation Algorithms for Projection Games
Engineering and Applications track
Frederic Cazals, Deepesh Agarwal, Julio-Cesar Silva Araujo, Christelle Caillouet, David Coudert and Stephane Perennes. Connectivity Inference in Mass Spectrometry based Structure Determination Nir Halman, Giacomo Nannicini and James Orlin. A Practical FPTAS for Convex Stochastic Dynamic Programs Sander P. A. Alewijnse, Quirijn W. Bouts, Alex P. ten Brink and Kevin Buchin. Computing the Greedy Spanner in Linear Space Andreas Beckmann, Ulrich Meyer and David Veith.
An Implementation of I/O-efficient Dynamic Breadth-First
Search using level-aligned hierarchical Clustering
Kai Xiao, Danny Z. Chen, X. Sharon Hu and Bo Zhou. Shell: A Spatial Decomposition Data Structure for 3D Curve Traversal on Many-core Architectures Jeremy Barbay, Ankur Gupta, Seungbum Jo, Srinivasa Rao Satti and Jonathan Sorenson. Theory and Implementation of Online Multiselection Algorithms Shin-Ichi Minato. Z-Skip-Links for Fast Traversal of ZDDs Representing Large-Scale Sparse Datasets Mark De Berg and Dirk H.P. Gerrits. Labeling Moving Points with a Trade-Off Between Label Speed and Label Overlap Sándor Laki and Tamás Lukovszki. Balanced Neighbor Selection for BitTorrent-like Networks
