Workshop on Algorithms in Bioinformatics 2013 - Accepted papers
Nicolas Wieseke, Matthias Bernt and
Martin Middendorf. Unifying
Parsimonious Tree Reconciliation Michał Modzelewski
and Norbert Dojer. MSARC:
Multiple Sequence Alignment by Residue
Clustering Arnon Mazza, Irit Gat-Viks, Hesso
Farhan and Roded Sharan. A Minimum-Labeling Approach for
Reconstructing Protein Networks across Multiple
Conditions Rolf Backofen, Markus Fricke, Manja
Marz, Jing Qin
and Peter F. Stadler. Graph-Distance within RNA Secondary
Structure Ensembles Sudheer Vakati and David
Fernández-Baca. Characterizing Compatibility and
Agreement of Unrooted Trees via Cuts in
Graphs Denisa Duma, Mary Wootters,
Anna Gilbert, Hung Q. Ngo, Atri Rudra, Matthew
Alpert, Timothy J. Close, Gianfranco Ciardo and
Stefano Lonardi. Accurate Decoding of Pooled Sequenced
Data Using Compressed Sensing João
Paulo Pereira Zanetti, Priscila Biller and João
Meidanis. On the
matrix median problem Jesper
Jansson, Chuanqi Shen and Wing-Kin
Sung. Algorithms for the Majority Rule
(+) Consensus Tree and the Frequency Difference
Consensus Tree Kamil Salikhov,
Gustavo Sacomoto and Gregory
Kucherov. Using cascading Bloom filters
to improve the memory usage for de Brujin
graphs Gustavo Sacomoto,
Marie-France
Sagot and Vincent
Lacroix. A polynomial delay
algorithm for the enumeration of
bubbles with length constraints in
directed graphs and its application to
the detection of alternative splicing
in RNA-seq data Evgeny Kapun
and Fedor
Tsarev. On NP-Hardness of the
Paired de Bruijn Sound Cycle
Problem Sebastian
Böcker, Stefan Canzar and
Gunnar
W. Klau. The
generalized Robinson-Foulds
metric Son
Pham, Ilya Minkin, Nikolay
Vyahhi, Anand Patel
and Mikhail
Kolmogorov. Sibelia: A
scalable and
comprehensive synteny
block generation tool for
closely related microbial
genomes Ramanuja
Simha and Hagit
Shatkay. Protein
(Multi-)Location
Prediction: Using
Location
Inter-Dependencies
in a Probabilistic
Framework Charalampos
Tsourakakis. Modeling
Intratumor Gene
Copy Number
Heterogeneity
using
Fluorescence in
Situ
Hybridization
data Viraj
Deshpande and
Eric
Fung. A
hybrid assembly
using high
throughput
short and long
reads Xuefeng
Cui, Shuai
Cheng Li,
Dongbo
Bu and
Ming
Li. Towards
Reliable
Automatic
Protein
Structure
Alignment Balaji
Venkatachalam,
Dan
Gusfield
and
Yelena
Frid. Faster
Algorithms
for
RNA-folding
using the
Four-Russians
method
